Arduino first steps
If you have never worked with Arduino before, this page describes how to start with your Arduino that you can purchase via the shop Shopping.png.
All you need to run the example below is:
  • One Arduino Nano (or Arduino Mega2560)
  • One USB cable
If your Arduino is not recognised as an USB device after plug-in, try a different USB cable.
You may need to install a driver for your Arduino:
  • Arduino Nano: Click here to download 'FTDI CDM 2.08.24'
  Note: Do NOT use the newest FTDI drivers as they may make your Arduino malfunction). Here are the steps to remove any newer driver:
  1. In Windows, choose 'Computer->Properties->Extended system settings->Hardware device settings'
  2. Set 'Should Windows install drivers automatically?' to 'NO'
  3. Activate 'Never install drivers via Windows Update'
  4. Run CDM Uninstaller
  5. Click 'Add', then 'Remove Devices'
  6. Restart your computer
  7. Re-plug Arduino Nano, now Windows should ask for driver installation, and you can choose the correct driver version (2.08.24)
  • Arduino Mega 2560:
  1. Download the Arduino development software (link in next section below) to your computer
  2. Navigate to and select the driver file named "arduino.inf", located in the "Drivers" folder of the Arduino Software download.
2. Download
Click here to download the Arduino development software (v1.6.3) to your computer
(Windows users should download the 'Installer' version on that page):
3. Install
For Windows users, double click the downloaded file ('arduino-1.6.3-windows.exe') in your
4. Run
After the installation completed, run the Arduino development software on your computer
by double clicking the 'Arduino' symbol on your Windows desktop.
5. Choose blink example
After the Arduino development software has started, choose the menu,
and click on 'File->Examples->Basics->Blink'. This will load the Arduino blink example.
6. Choose correct board type
Via the menu, click on 'Tools->Board->Arduino Nano' to choose your Nano board
(or Arduino Mega 2560 if you want to use a Mega board).
8. Upload the blink example
Click on the 'Upload' symbol to upload the blink example to your Arduino.
After the code is uploaded, your Arduino will start to blink!
Congratulations!
Now let's look a little bit closer at the above blink code to understand it:
The Arduino has several pins, each of them has a number.  As shown below, Pin 13 is already (internally) connected to the on-board LED:
Each pin can be configured as either INPUT or OUTPUT depending on wheter you want
to measure or control that pin :
 INPUT   means that you can read (or measure) that pin. The measurement can be either ON
 (there is voltage on that pin)  or OFF (there is no voltage on that pin).
 OUTPUT   means that you can write (or control) the voltage of that pin.
In the blink example above, we are using the LED pin (pin 13) that is already connected to an LED.
Because we want to control that pin, we are configuring it as OUTPUT:
 pinMode(13, OUTPUT);
 digitalWrite(13, HIGH);
 digitalWrite(13, LOW);
Let's see how we can wait one second between the ON and OFF toggling. This command will wait (halt)
the program for one second (=1000 milliseconds):
 delay(1000);
So let's look at the complete blink program again:
 void setup(){
   pinMode(13, OUTPUT);      // we want to control pin 13
 void loop(){
   digitalWrite(13, HIGH);   // pin 13 will go HIGH (voltage ON)
   delay(1000);              // wait one second (=1000 milliseconds)
   digitalWrite(13, LOW);    // pin 13 wil go LOW (voltage OFF)
   // ...now everything repeats
How to go further...
