Ardumower Chassis 'mountain mod'
This page describes how to modify the Ardumower Chassis to run up higher slopes with it (tested up to 30 percent). This works by
  2. modifying the tire profile (give it more grip)
    1. Modify tire profile OR
    2. Off-road version (sand etc.): A bicycle tube is added around the tire
Needed parts
  • cup
  • acrylic glas sheet
  • rubber band
  1. swap motor cables (right and left)
  2. swap odometry cables (right and left)
  3. swap battery charging pin cables (right and left)
  4. disable ultrasonic sensor
  5. move perimeter coil from old front to old back side
  1. Demo
  2. Optimized tires
  3. Bicycle tube tires for 'off-road'
  4. Ardumower rear/front driven climbing difference
Other ideas
