NOTE: THIS IS ONLY AN IDEA - NOT IMPLEMENTED IN ARDUMOWER (YET)
- 1 Abstract
- 2 Requirements
- 3 Message format
- 4 Messages
- 14 Event: odometry data
- 15 Event: GPS data
- 17 Event: drop sensor data
- 18 Event: IMU data
- 20 Proprietary messages
TODO:
- add robot setup commands
Message format
message components:
- $: start of message symbol
Messages
commands:
events:
- $RMBUM: bumper sensor event
- $RMODO: odometry event
- $RMGPS: GPS event
- $RMDRO: drop sensor event
- $RMIMU: IMU event
$RMREQ,MSG,f,t<cr><lf>
$RMMOW,s<cr><lf>
$RMMOV,m,l,r,p,i,d<cr><lf>
- l: left motor target rpm
- r: right motor target rpm
- p: PID_Kp
- i: PID_Ki
- d: PID_Kd
$RMKOA<cr><lf>
- ts: timestamp ms
- e: error code
- b: battery percent
- bl: battery low (0/1)
- c: charging percent
- o: Odometry available (1/0)
- g: GPS available (1/0)
- ts: timestamp ms
- ts: timestamp ms
- ul: ultrasonicLeft meter
- ur: ultrasonicRight meter
- uc: ultrasonicCenter meter
- ts: timestamp ms
- bl: bumperLeft value
- br: bumperRight value
- bc: bumperCenter value
$RMODO,ts, ol, or
- ts: timestamp ms
- ol: left odometry
- or: right odometry
Event: GPS data
$RMGPS,ts, ga, go
- ts: timestamp ms
- ga: GPSlatitude
- go: GPSlongitude
- ts: timestamp ms
$RMDRO,ts,dl,dr,dlt,drt
- ts: timestamp ms
Event: IMU data
$RMIMU,ts,ih,ip,ir,tr
- ts: timestamp ms
- ip: IMUpitch degree
- ir: IMUroll degree
- tr: tilt triggered (0/1)
- t: timestamp ms
