Wheel Motor
Wheel motors caracteristics & driver
- steer the robot left/right
- Integrated encoders, so it can measure the rotation speed, the distance and the direction (see Odometry for more information) - Encoders are REQUIRED for Ardumower software.
- 24V (load current ~1A)
Wiring
Using motor driver MC33926 :
Right | Left
Pin 33 | Pin 31 One pin controls the direction (forward/backward)
Pin 03 | Pin 05 the other pin controls the speed.
Pin A0 | Pin A1 One analog input pin is connected to the current sensor.
Pin 27 | Pin 25 input pin to read fault
Protector board is adviced to be used between controler and motor.
Alternative solution
The current sensor module (ACS712-05A) is connected in series with the motor.
Control principal : PWM frequency
Motor controller (PID)
Programming
Motor variables
// --------- wheel motor state ---------------------------- // wheel motor speed ( <0 backward, >0 forward); range -motorSpeedMaxRpm..motorSpeedMaxRpm // [Default value] float motorAccel ; // motor wheel acceleration - only functional when odometry is not in use // (warning: do not set too high) [1000] int motorSpeedMaxRpm ; // motor wheel max RPM [25] int motorSpeedMaxPwm ; // motor wheel max Pwm (8-bit PWM=255, 10-bit PWM=1023) [255] float motorPowerMax ; // motor wheel max power (Watt) PID motorLeftPID; // motor left wheel PID controller [Kp=1.5 , Kd=0.29, Ki=0.25] PID motorRightPID; // motor right wheel PID controller float motorSenseRightScale ; // motor right sense scale (mA=(ADC-zero)/scale) float motorSenseLeftScale ; // motor left sense scale (mA=(ADC-zero)/scale) int motorRollTimeMax ; // max. roll time (ms) int motorRollTimeMin ; // min. roll time (ms) int motorReverseTime ; // max. reverse time (ms) long motorForwTimeMax; // max. forward time (ms) / timeout float motorBiDirSpeedRatio1 ;// bidir mow pattern speed ratio 1 float motorBiDirSpeedRatio2 ;// bidir mow pattern speed ratio 2 bool motorRightSwapDir ; // inverse right motor direction? bool motorLeftSwapDir ; // inverse left motor direction? int motorLeftSpeedRpmSet ; // set speed int motorRightSpeedRpmSet ; float motorLeftPWMCurr ; // current speed float motorRightPWMCurr ; int motorRightSenseADC ; int motorLeftSenseADC ; float motorLeftSenseCurrent ; float motorRightSenseCurrent ; float motorLeftSense ; // motor power (range 0..MAX_MOTOR_POWER) float motorRightSense ; int motorPowerIgnoreTime; int motorZeroSettleTime; // how long (ms) to wait for motor to settle at zero speed int motorLeftSenseCounter ; // motor current counter int motorRightSenseCounter ; unsigned long nextTimeMotorSense ; unsigned long lastSetMotorSpeedTime; unsigned long motorLeftZeroTimeout; unsigned long motorRightZeroTimeout; boolean rotateLeft; unsigned long nextTimeRotationChange;
Motor Methods
First the basic function that control the pwm to each motors:
void setMotorPWM(int pwmLeft, int pwmRight, boolean useAccel);
A general methods to test motors
void testMotors();
Then, there are several MotorControl methods according to mower state :
if current state is 'STATE_PERI_TRACK' then
void motorControlPerimeter();
void motorControlImuRoll();
void motorControlImuDir();
for all other case :
void motorControl(); // This method calculate pwm to set in order to respect rpm setpoint according current rpm and Kp, Ki, Kd parameter
Motors testing
Test consist of the following sequence :
- Left motor : Forward half speed
- Left motor : Reverse full speed
- Right motor : Forward half speed
- Right motor : Reverse full speed
NB : If motor rotation is inverse to what is expected, then you need to switch the wiring at the outlet of motor controller.
