Maintenance Repair Tips
Version vom 6. September 2021, 20:11 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Motor bearing is stiff or making noise)
Clamping element will not tighten shaft anymore
If your 'clamping' element will not tighten shaft anymore (e.g. due to a slightly reduced shaft diameter), you may:
  • press together the outer clamping element in a bench vise
  • OR use a filling under the 'ring'. Soda/beer can strip works fine for that. Wedged parts has slits, make sure those are not towards each other nor towards shaft d-slot.
  • OR add a heat shrink tubing over the inner clamping element as shown in the photo (NOTE: this is a temporary solution and may not last forever as the heat shrink tubing may dissolve over time):
Replace motor bearing by a new one:
mower motor ball bearing type: 608-ZZ (22mm diameter, 7mm width, 8mm hole)
