AzuritBer RFID option (English)
Description
It's very useful on big mowing area or complex one with a lot of island.
Hardware connecting
FIRMWARE ESP32
see here :
https://wiki.ardumower.de/index.php?title=AzuritBer_ESP32_option_(English)
you need to activate the RFID in config.h before uploading code in the ESP32
#define rfid_board_IsPluged true //Set to true or false according your hardware
If everything is OK you can see Last Rfid tag code into Arduremote / setting / RFID each time you move a tag near the reader and if it's a new tag : a record is add with a WAIT status and nothing to do.
Setting
2 Value need to match to have a mower react (TODO) : TAG Nr AND Mower STATUS
Edit a record
Be careful To edit existing tag : click on the list to choose the tag you want to edit.Click on Delete This Tag to remove old tag from list.Now change value on the text box on right part of the screen , and click on Add this Tag to add the new one.Do not forget to save to file.
What is possible
Mower can DO : 'RTS' or 'FAST_START' or 'SPEED' or 'AREA1' or 'AREA2' or 'AREA3'
Fast Return to station
RTS can be use to escape from island or simply fast return to station :
Speed and Ang 1 are used
When tag 72B8DB95 is find AND mower Status is BACK_TO_STATION ,if you put RTS in the TODO column : Mower stop tracking roll 28 Degree and run at new PWM speed of 250 to find again the wire and continue tracking.
Fast Start
When tag 1AD8DB95 is find AND mower Status is TRACK_TO_START ,if you put FAST_START in the TODO column : Mower stop tracking roll 50 Degree and run at new PWM speed of 250 to find again the wire and continue tracking.
Can be use to Dock at low speed or simply change tracking speed when you want : ON big straight line mower can track at PWM=255 or on hard angle you can reduce the tracking speed
Speed and Dist1 are used.
Go to new mowing Area
Can be use to Go to a new mowing area (with other sender) :
It is used to back to charging station from other mowing area :
Result in Video
Here a fast start to go in area2 :
At 1:34 The AREA2 tag is find : mower stop to read area1 signal and start to go to area2 (NO wire under asphalt)
AT 2:56 mowing in AREA2 start
At 1:52 Change area tag is find : Mower stop AREA2 sender and move to AREA1 without reading perimeter signal.
