Arduino first steps
If you have never worked with Arduino before, this page describes how to start with your Arduino that you can purchase via the shop Shopping.png.
All you need to 'upload' the example code to your Arduino is:
  • One Arduino Nano (or Arduino Mega2560)
  • One USB cable
2. Download
Click here to download the Arduino development software (v1.5.8) to your computer
(Windows users should download the 'Installer' version on that page):
3. Install
4. Run
After the installation completed, run the Arduino development software on your computer
by double clicking the 'Arduino' symbol on your Windows desktop.
5. Choose blink example
After the Arduino development software has started, choose the menu,
and click on 'File->Examples->Basics->Blink'. This will load the Arduino blink example.
6. Choose correct board type
Via the menu, click on 'Tools->Board->Arduino Nano' to choose your Nano board
(or Arduino Mega 2560 if you want to use a Mega board).
8. Upload the blink example
Click on the 'Upload' symbol to upload the blink example to your Arduino.
After the upload completed, your Arduino will start to blink!
Congratulations!
Now let's look a little bit closer at the above blink code to understand it:
The Arduino has several pins, each of them has a number.  As you can see, Pin 13 is already connected to the on-board LED:
Each pin can be configured as either INPUT or OUTPUT
depending on wheter you want to measure (read) or control (write) to it:
 INPUT   means that you can read (or measure) that pin. The measurement can be either ON
 (there is voltage on that pin)  or OFF (there is no voltage on that pin).
 OUTPUT   means that you can write (or control) the voltage of that pin.
In the blink example above, we are using the LED pin (pin 13) that is already connected to an LED.
Because we want to control that pin,we are configuring it as OUTPUT:
 pinMode(13, OUTPUT);
 digitalWrite(13, HIGH);
 digitalWrite(13, LOW);
 delay(1000);
So let's look at the complete blink program again:
 void setup(){
   pinMode(13, OUTPUT);      // we want pin 13 an OUTPUT pin
 void loop(){
   digitalWrite(13, HIGH);   // pin 13 should be ON
   delay(1000);              // wait one second (=1000 milliseconds)
   digitalWrite(13, LOW);    // pin 13 should be OFF
How to go further...
