Arduino first steps
Version vom 24. November 2014, 13:22 Uhr von Alexanderg (Diskussion | Beiträge)
All you need to 'upload' the example code to your Arduino is:
- One USB cable
2. Download
Click here to download the Arduino development software (v1.5.8) to your computer (Windows users should download the 'Installer' version on that page):
3. Install
4. Run
5. Choose blink example
6. Choose correct board type
8. Upload the blink example
Click on the 'Upload' symbol to upload the blink example to your Arduino. After the upload completed, your Arduino will start to blink!
Congratulations!
Now let's look a little bit closer at the above blink code to understand it:
The Arduino has several pins, each of them has a number. As you can see, Pin 13 is already connected to the on-board LED:
Each pin can be configured as either INPUT or OUTPUT depending on wheter you want to measure or control that pin :
OUTPUT means that you can write (or control) the voltage of that pin.
pinMode(13, OUTPUT);
digitalWrite(13, HIGH);
digitalWrite(13, LOW);
delay(1000);
So let's look at the complete blink program again:
void setup(){
pinMode(13, OUTPUT); // we want to control pin 13
void loop(){
digitalWrite(13, HIGH); // pin 13 will go HIGH (voltage ON)
delay(1000); // wait one second (=1000 milliseconds)
digitalWrite(13, LOW); // pin 13 wil go OFF (voltage OFF)
// ...now everything repeats
How to go further...
