Alfred Assembly
Version vom 17. Mai 2023, 09:17 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Programming your Alfred MCU firmware)
This page describes the assembly of the Alfrd DIY kit that you can purchase via the [1] Shopping.png.
  1. Alfred DIY - Montage des Bedienpanels
  2. Montage der RTK Basisstation | Assembly of RTK base | ArduMower / Alfred
Assembly of the LED-Board
Connection of electricity thieves
The enclosed electricity thieves are to divert the supply voltage from Alfred. Please press the black cable (-) to the black cable from the red connector (battery cable) and the red cable (+) to the black cable from the blue connector (on/off switch).
Remaining ribbon cable from the control panel
You can remove or cut off the two remaining ribbon cables on the original control panel, insulate the ends and stow them in the housing.
1. Connect the Alfred PCB ribbon cable to the robot MCU (cable 2).
2. Download the Sunray Manual and install the App as described in the Sunray manual.
3. Via the App, connect with the Alfred PCB (either Bluetooth or WiFi). Once connected to the Alfred PCB, the Sunray App will show a default voltage ('28v').
4. Choose 'Menu->Firmware->Apply Update' to flash the Alfred MCU firmware (NOTE: this process will take 2-3 minutes).
5. Restart the App and verify that the 'MCU firmware' is shown:
