Arduino first steps
Version vom 23. April 2015, 22:01 Uhr von Autega (Diskussion | Beiträge)
All you need to run the example below is:
- One USB cable
You may need to install a driver for your Arduino:
- Arduino Nano: Click here to download 'FTDI CDM 2.08.24'
Note: Do NOT use the newest FTDI drivers as they may make your Arduino malfunction). Here are the steps to remove any newer driver: 1. In Windows, choose 'Computer->Properties->Extended system settings->Hardware device settings' 2. Set 'Should Windows install drivers automatically?' to 'NO' 3. Activate 'Never install drivers via Windows Update' 4. Run CDM Uninstaller 5. Click 'Add', then 'Remove Devices' 6. Restart your computer 7. Re-plug Arduino Nano, now Windows should ask for driver installation, and you can choose the correct driver version (2.08.24)
- Arduino Mega 2560:
1. Download the Arduino development software (link in next section below) to your computer 2. Navigate to and select the driver file named "arduino.inf", located in the "Drivers" folder of the Arduino Software download.
2. Download
Click here to download the Arduino development software (v1.6.3) to your computer (Windows users should download the 'Installer' version on that page):
3. Install
For Windows users, double click the downloaded file ('arduino-1.6.3-windows.exe') in your
4. Run
5. Choose blink example
6. Choose correct board type
8. Upload the blink example
Click on the 'Upload' symbol to upload the blink example to your Arduino.
After the code is uploaded, your Arduino will start to blink!
Congratulations!
Now let's look a little bit closer at the above blink code to understand it:
The Arduino has several pins, each of them has a number. As shown below, Pin 13 is already (internally) connected to the on-board LED:
Each pin can be configured as either INPUT or OUTPUT depending on wheter you want to measure or control that pin :
OUTPUT means that you can write (or control) the voltage of that pin.
pinMode(13, OUTPUT);
digitalWrite(13, HIGH);
digitalWrite(13, LOW);
delay(1000);
So let's look at the complete blink program again:
void setup(){
pinMode(13, OUTPUT); // we want to control pin 13
void loop(){
digitalWrite(13, HIGH); // pin 13 will go HIGH (voltage ON)
delay(1000); // wait one second (=1000 milliseconds)
digitalWrite(13, LOW); // pin 13 wil go LOW (voltage OFF)
// ...now everything repeats
How to go further...
