IMU
Version vom 24. Januar 2015, 16:29 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Lane-by-lane mowing)
Lane-by-lane mowing
IMU module GY-80
  • Compass sensor: HMC5883L
  • Gyro: L3G4200D
This photo shows how the IMU module is placed in driving position (the black arrow shows the driving position). The shown tube was needed to ensure a minimum distance of 30cm from all motors. This minimum distance seems to be needed to ensure the compass is not disturbed by dynamically disturbing sources (like motors).
Calibration abstract
  • All 3 axes measurements of the acceleration sensor are weighted equally. This calibration can be performed even outside of the robot.
  • Cable, metal, etc. which is located in the robot near the IMU module has no effect on the compass data.
Why is it needed? A measured value (x, y, z) of a 3D compass points (as seen by his origin 0,0,0) always in one direction: to the north pole. If you rotate the 3D compass around all of its axes, all measured values ​​lie on a sphere:
Example measurements
Calibration (v0.9.3)
2.1. After calibration, each of the 6 sides of the module has to look up-side and down-side (rotated 180 °). The module has 6 sides, so it must be rotated 6 times, so that each side once is on the table (you can hold the module with your hand without moving it). Press ENTER after each calibration step. The aim of the calibration to determine the acceleration due to gravity (more precisely, the minimum / maximum value) for each axis . The module must not be artificially accelerated. The order of the sides does not matter.
1. Download ArduMag calibration app for Android. 2. If not done yet, pair your Android device with the Bluetooth module: On the Android device main screen, choose symbol "Settings" (via Android menu). Now choose "Wirless and Networks->Bluetooth Settings" and "Find device". Finally, choose "pair with this device" and enter your pin (very often "1234"). The Bluetooth module should now appear as "paired". 3. In the ArduMag app, press the Android menu key and then "Bluetooth" to connect with your Bluetooth module (and your robot). The robot should confirm the connection with a beep. The number of measurements should increase.
The order of the axis of rotation and the direction does not matter. For example, rotate each side 180 degree clockwise and then again 180 degree counterclockwise (result is a 360 degree rotation). The measurements may not fit a sphere. Examples:
Finally, press 'Calibrate' to finish the calibration. The robot will confirm the calibration with two beeps. The measurements should fit a sphere now. Examples:
Compass deviation
Calibration test
Testing of compass and tilt angles (via serial console)
The Arduino outputs:
Testing (by using LED)
Testing (via Android pfodApp)
Calibration (SVN version)
Calibration quality test
Table test
calls=30    yaw=-95.56    pitch=0.02    roll=2.52    com=-95.91    com180=84.09    gyroZ=0.00
calls=30    yaw=-95.48    pitch=-0.11    roll=2.33    com=-95.81    com180=84.19    gyroZ=-0.01
calls=30    yaw=-95.42    pitch=0.03    roll=2.42    com=-95.65    com180=84.35    gyroZ=-0.00
calls=30    yaw=-95.45    pitch=-0.21    roll=2.38    com=-95.35    com180=84.65    gyroZ=-0.00
calls=30    yaw=85.06    pitch=-2.50    roll=0.04    com=84.91    com180=-95.09    gyroZ=-0.03
calls=30    yaw=84.90    pitch=-2.59    roll=0.05    com=84.63    com180=-95.37    gyroZ=-0.02
calls=30    yaw=85.19    pitch=-2.55    roll=0.01    com=84.73    com180=-95.27    gyroZ=-0.01
calls=30    yaw=84.98    pitch=-2.73    roll=0.02    com=84.85    com180=-95.15    gyroZ=-0.01
pfodApp test
  1. Robot dance
  2. Keep on track
  3. Driving lanes
