Version vom 28. Januar 2015, 17:20 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Mapping and localization (SLAM))
Sensor errors
Odometry sensor
  • Distance: 20cm per meter
  • Course: 10 degree per meter
Input to SLAM algorithm:
  • control values (speed, steering)
  • observation values (speed, heading, magnetic field strength)
Output from SLAM algorithm:
  • magnetic field map (including perimeter border)
  • robot position on that map (x,y,theta)
Example SLAM algorithms:
  • Particle filter-based SLAM plus Rao-Blackwellization: model the robot’s path by sampling and compute the 'landmarks' given the poses
Lane-by-lane mowing
