Version vom 28. Januar 2015, 17:26 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Lane-by-lane mowing)
Sensor errors
Odometry sensor
  • Distance: 20cm per meter
  • Course: 10 degree per meter
  1. Calculation of short-time position by Odometry and Compass
  2. Calculation of long-term position via GPS
A Kalman filter can be used to fuse all sensor values.
Position recalibration
  1. Learn mode: robot completely tracks perimeter wire once and saves course (degree) and distance (odometry ticks) in a list (perimeter tracking map).
  2. Position detection: robot starts tracking the perimeter wire at arbitrary position until a high correlation with a subtrack of the perimeter tracking map is found. There it can stop tracking and knows its position on its perimeter tracking map.
Mapping and localization (SLAM)
Input to SLAM algorithm:
  • control values (speed, steering)
  • observation values (speed, heading, magnetic field strength)
Output from SLAM algorithm:
  • magnetic field map (including perimeter border)
  • robot position on that map (x,y,theta)
Example SLAM algorithms:
  • Particle filter-based SLAM plus Rao-Blackwellization: model the robot’s path by sampling and compute the 'landmarks' given the poses
Lane-by-lane mowing
Simulation
