- speed (m/s)
- direction (degree)
- position (x,y - meter)
Sensor errors
- Compass: noise (e.g. 0.05 degree per second), update rate: 10-20 Hz
Odometry sensor error
- Distance: 20cm per meter
- Course: 10 degree per meter
Position recalibration at perimeter border
Mapping and localization (SLAM)
Input to SLAM algorithm:
Output from SLAM algorithm:
Example SLAM algorithms:
SLAM simulation
Videos:
Lane-by-lane mowing
Assuming a lane length of 10m, and a lane width error of +/- 0.2m, the maximum allowed yaw error is:
yaw error=arcsin(0.2/10) = 1.1 degree
Simulation
