Ardumower Mini
This page describes the 'Ardumower Mini' that can be used to implement a full Ardumower for indoor software development and
that you can purchase via the shop
Needed parts
Pictures
Steps
The Ardumower Mini can run the same software as the 'big Ardumower'. For the PCB, you don't need to use a Ardumower PCB - instead you can (with some limitation) connect the components directly as shown below. The limitations are: there will be no battery charging circuit, and of course your wiring will not look as nice as a ready PCB :-)
For software download, see the ['http://wiki.ardumower.de/index.php?title=Ardumower_PCB Ardumower PCB/code page].
NOTE: Do not use more than 7 volt to operate the DC motors!
1. Start button
Button (a) --- Arduino pinButton (see code) Button (b) --- GND
2. Piezo buzzer
Buzzer (a) --- Arduino pinBuzzer (see code) Buzzer (b) --- GND
3. Motor driver
3.1 For L298N motor driver
+5v --- leave open +12v --- LiPo 2s battery 7volt (+) GND --- LiPo 2s battery 7volt (-) ENA --- insert jumper (enables OUT1,2) IN1 --- Arduino pinMotorLeftPWM (see code) IN2 --- Arduino pinMotorLeftDir (see code) IN3 --- Arduino pinMotorRightPWM (see code) IN4 --- Arduino pinMotorRightDir (see code) ENB --- insert jumper (enables OUT3,4) S1 --- insert jumper (enables 5v regulator for +12v voltage input) OUT1 --- left motor (+) OUT2 --- left motor (-) OUT3 --- right motor (+) OUT4 --- right motor (-)
3.2 For MC33926 motor driver
M1_FB --- Arduino pinMotorLeftSense (see code) M1_SF --- Arduino pinMotorLeftFault (see code) M1_PWM_D1 --- connect with jumper to GND M1_PWM_D2 --- connect with jumper to VDD M1_IN1 --- Arduino pinMotorLeftPWM (see code) M1_IN2 --- Arduino pinMotorLeftDir (see code) EN --- Arduino pinMotorEnable (see code) M2_FB --- Arduino pinMotorRightSense (see code) M2_SF --- Arduino pinMotorRightFault (see code) M2_PWM_D1 --- connect with jumper to GND M2_PWM_D2 --- connect with jumper to VDD M2_IN1 --- Arduino pinMotorRightPWM (see code) M2_IN2 --- Arduino pinMotorRightDir (see code) EN --- Arduino pinMotorEnable (see code) VDD --- Arduino 5V M1OUT1 --- left motor (+) M1OUT2 --- left motor (-) M2OUT1 --- right motor (+) M2OUT2 --- right motor (-) VIN --- LiPo 2s battery 7volt (+) GND --- LiPo 2s battery 7volt (-)
4. Arduino Mega
Power jack --- LiPo 2s battery 7volt (outside is-/inside is+) pinMotorLeftPWM --- left motor speed (see code pinMotorLeftDir --- left motor direction (see code) pinMotorRightPWM --- right motor speed (see code) pinMotorRightDir --- right motor direction (see code)
5. Bluetooth receiver
VCC5.0 --- Arduino 5v (for 5v Bluetooth version) VCC3.3 --- Arduino 3.3v (for 3.3v Bluetooth version) TXD --- Arduino RX2 RXD --- Arduino TX2 GND --- Arduino GND
6. Sonar (ultrasonic)
VCC --- Arduino 5v Trig --- Arduino pinSonarCenterTrigger (see code) Echo --- Arduino pinSonarCenterEcho (see code) GND --- Arduino GND
7. Model R/C
VCC --- Arduino 5v CHANNEL steer --- Arduino pinRemoteSteer (see code) CHANNEL speed --- Arduino pinRemoteSpeed (see code)
8. IMU (compass/gyro/accel)
SDA --- Arduino SDA SCL --- Arduino SCL GND --- Arduino GND VCC5.0 --- Arduino 5v
9. Perimeter receiver
VCC --- Arduino 5v IN --- coil (a) GND --- coil (b) GND --- Arduino GND Out --- Arduino pinPerimeterLeft (see code)
