Odometry ru
Version vom 23. August 2015, 15:08 Uhr von Unlogic (Diskussion | Beiträge) (→‎Motor controller (PID))
Latest Ardumower code requires motor encoders for odometry. Using odometry you can calculate the robot's speed and the short-term position of the robot. This works by counting the rotations of left and right wheel (motor encoders - required by latest Ardumower software).
Currently, odometry is used:
  • to ensure the robot left and right wheel are turning the same speed (in forward direction)
Encoder pinout (Ardumower motors)
The Ardumower has a 2-channel encoder with 5 pulses at one cycle of motor multiplied by gear ratio 1:212, resulting in 1060 encoder ticks per one full tire resolution.
Wiring/pinout of motor encoder connector:
green  ---- GND
brown  ---- VCC
blue   ---- odometry1
purple ---- odometry2
odometry1 --- 4.7k --- 5v
odometry2 --- 4.7k --- 5v
Signal of odometry encoders
Forward: pin1 makes LOW->HIGH transition and pin2 = HIGH
Reverse: pin1 makes LOW->HIGH transition and pin2 = LOW
Do-It-Yourself encoders
Circuit
VCC           pinArduino
+--13 KOhm----+-------Collector  Emitter---GND
+--380 Ohm------------Anode      Kathode---GND
Differential drive
By adding (integrating) Odometry speed, we can calculate distance and heading.
Distance per wheel:
left_cm  = ticksLeft  / odometryTicksPerCm
right_cm = ticksRight / odometryTicksPerCm
Heading:
wheel_theta = (left_cm - right_cm) / odometryWheelBaseCm
odometryTheta += wheel_theta
Overall distance:
avg_cm  = (left_cm + right_cm) / 2.0
odometryX += avg_cm * sin(odometryTheta)
odometryY += avg_cm * cos(odometryTheta)
Ground measurement error
By adding (integrating) Odometry speed, we can calculate distance and heading. However, as we are adding a small error each time (due to not exact physical ground measurement), distance and angle errors are increasing. This can be solved by sensor fusion.
Регулятор скорости мотора (ПИД)
Скорость двигателей регулируется с помощью программного ПИД-регулятора. Вы можете следить за качеством управления скорости через pfodApp (Plot->Motor control):
Видео
Еще нет видео (функционал в разработке)
