Wheel Motor
Wheel motors caracteristics & driver
- steer the robot left/right
- Integrated encoders, so it can measure the rotation speed, the distance and the direction (see Odometry for more information) - Encoders are REQUIRED for Ardumower software.
- 24V (load current ~1A)
Wiring
Protector board is adviced to be used between controler and motor.
Control principal : PWM frequency
Motor controller (PID)
Programming
Motor variable
// --------- wheel motor state ---------------------------- // wheel motor speed ( <0 backward, >0 forward); range -motorSpeedMaxRpm..motorSpeedMaxRpm float motorAccel ; // motor wheel acceleration (warning: do not set too high) int motorSpeedMaxRpm ; // motor wheel max RPM int motorSpeedMaxPwm ; // motor wheel max Pwm (8-bit PWM=255, 10-bit PWM=1023) float motorPowerMax ; // motor wheel max power (Watt) PID motorLeftPID; // motor left wheel PID controller PID motorRightPID; // motor right wheel PID controller float motorSenseRightScale ; // motor right sense scale (mA=(ADC-zero)/scale) float motorSenseLeftScale ; // motor left sense scale (mA=(ADC-zero)/scale) int motorRollTimeMax ; // max. roll time (ms) int motorRollTimeMin ; // min. roll time (ms) int motorReverseTime ; // max. reverse time (ms) long motorForwTimeMax; // max. forward time (ms) / timeout float motorBiDirSpeedRatio1 ; // bidir mow pattern speed ratio 1 float motorBiDirSpeedRatio2 ; // bidir mow pattern speed ratio 2 bool motorRightSwapDir ; // inverse right motor direction? bool motorLeftSwapDir ; // inverse left motor direction? int motorLeftSpeedRpmSet ; // set speed int motorRightSpeedRpmSet ; float motorLeftPWMCurr ; // current speed float motorRightPWMCurr ; int motorRightSenseADC ; int motorLeftSenseADC ; float motorLeftSenseCurrent ; float motorRightSenseCurrent ; float motorLeftSense ; // motor power (range 0..MAX_MOTOR_POWER) float motorRightSense ; int motorPowerIgnoreTime; int motorZeroSettleTime; // how long (ms) to wait for motor to settle at zero speed int motorLeftSenseCounter ; // motor current counter int motorRightSenseCounter ; unsigned long nextTimeMotorSense ; unsigned long lastSetMotorSpeedTime; unsigned long motorLeftZeroTimeout; unsigned long motorRightZeroTimeout; boolean rotateLeft; unsigned long nextTimeRotationChange;
