Arduino crash course
Version vom 13. September 2014, 09:39 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Your first program)
Your first program
This will make the onboard Arduino LED to blink (by toggling Arduino pin 13 between 5V and 0V):
 // This is run only once after the Arduino starts. The command 'pinMode' configures the Arduino LED pin 13
 void setup() {
   pinMode(13, OUTPUT);
 // This will be run over and over (so forever). It's the main loop of the program.
 void loop() {
   digitalWrite(13, HIGH);    // set pin 13 to 5V/HIGH
   delay(1000);               // wait 1000 milliseconds (=1 second)
   digitalWrite(13, LOW);     // set pin 13 to 0V/GND/LOW
Run this code in your Arduino IDE and see what happens with your onboard Arduino LED. Then try to adjust the example so that the LED blinks more quickly!
Expressions
Everything that can be calculated is an expression. Expressions are used to compute things. We will use expressions later for variables or functions calls.
Examples for expressions:
13               => can be computed to 13 (it's simple right?)
2 * 13           => can be computed to 26
42 - 9 * 100     => can be computed as everything is known to compute it
a + b - c + 20   => can be computed if a, b and c are known
Variables
A memory variable can contain a value (integer number, floating number, text character etc.). It is useful to use variables instead of repeating hard wired numbers. Here the same example, this time using a variable for the LED pin:
// declare an integer variable named 'pinLED' and assign it the value 13
int pinLED = 13;       // this is a comment
void setup() {
  pinMode(pinLED, OUTPUT);   // here, we use the variable named 'pinLED' instead of the hard-wired number
void loop() {
  digitalWrite(pinLED, HIGH);    // here, we use again the variable 'pinLED'
  delay(1000);
  digitalWrite(pinLED, LOW);     // here, we use again the variable 'pinLED'
  delay(1000);
Try it out! Variables can be integer number, floating numbers, logical (TRUE/FALSE), and text characters:
int someIntegerNumber = 42;
boolean someLogical = TRUE;
float someFloatingNumber = 3.1419;
char someCharacters[] = "Hello World";
A variable's contents can be re-assigned at any time in the program:
int pinLED = 13;   // declare variable named pinLED and initialize it with value 13
pinLED = 12;       // assign pinLED a new value (12)
You can even use calculations/expressions:
int A = 4;
int B = A * 42 + 15;
You may wonder what the values 'HIGH' and 'LOW' in the above code example are. These are integer constants that the Arduino library already did define for you (HIGH = 1, LOW = 0). Using variables and constants makes code more human-readable.
Functions
pinMode
digitalWrite
delay
void writeAndWait(int value){
  digitalWrite(pinLED, value);    // here, we use the parameter 'value' instead of a fixed HIGH/LOW value
  delay(1000);
void loop() {
  writeAndWait(HIGH);  // call function with 'HIGH' (for parameter 'value')
  writeAndWait(LOW);   // call function with 'LOW' (for parameter 'value')
  return a + b;
int c = addSomething( 4, 5 );
void setup(){
  Serial.begin(19200);  // set the baud rate to use
void loop(){
  delay(1000);
For-loops and blocks
Hello 0
Hello 1
Hello 2
Hello 3
... then the main loop restarts...
void loop(){
    Serial.print("Hello ");
    Serial.println(counter);
  delay(1000);
Try it out!
Digital input
int pinLED = 13;  // we use the Arduino onboard LED
void setup(){
  pinMode(pinSwitch, INPUT_PULLUP);
void loop(){
  Serial.println( value );
  delay(1000);
Try it out!
If-clauses
void loop(){
  if (value == HIGH){
  else  {
  delay(1000);
if (numberX > 5)... // variable 'numberX' must be larger than 5
if (numberX > numberY) ... // variable 'numberX' must be larger than variable 'numberY'
if (numberX == numberY) ... // 'numberX ' must be equal 'numberY'
if (numberX < numberY) ... // 'numberX' must be smaller than 'numberY'
if ( (number > 5) && (number < 10) )... // logical AND: both conditions must be TRUE
if ( (number < 5) || (number > 10) )... // logical OR: only one condition must be TRUE
What you have learned
  • Variables can contain numbers (integer, float) or text (characters) and are placeholders for them.
  • Functions can containe blocks of code and are placeholders for the blocks.
