IMU
Version vom 30. Mai 2016, 09:16 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Calibration (old v0.9.3))
                noise dps/sqrt(Hz)
L3G4200D        0.03
BMG160/BNO055   0.014
MPU9250         0.01
L3GD20H         0.011
LSM9DS0         0.00875
BMI160          0.007
MAX21003        0.007
L2G2IS/L2G3IS   0.006
MPU9150/MPU6050 0.005
ADXRS290        0.004
GYPRO2300       0.00277
Additionally, gyro/acceleration and compass sensors can be further input to a position estimation.
IMU modules
  • Compass sensor: HMC5883L
  • Gyro: L3G4200D
MPU9150
Calibration abstract
Example measurements
Calibration (latest version)
Calibration quality test
Table test
calls=30    yaw=-95.56    pitch=0.02    roll=2.52    com=-95.91    com180=84.09    gyroZ=0.00
calls=30    yaw=-95.48    pitch=-0.11    roll=2.33    com=-95.81    com180=84.19    gyroZ=-0.01
calls=30    yaw=-95.42    pitch=0.03    roll=2.42    com=-95.65    com180=84.35    gyroZ=-0.00
calls=30    yaw=-95.45    pitch=-0.21    roll=2.38    com=-95.35    com180=84.65    gyroZ=-0.00
calls=30    yaw=85.06    pitch=-2.50    roll=0.04    com=84.91    com180=-95.09    gyroZ=-0.03
calls=30    yaw=84.90    pitch=-2.59    roll=0.05    com=84.63    com180=-95.37    gyroZ=-0.02
calls=30    yaw=85.19    pitch=-2.55    roll=0.01    com=84.73    com180=-95.27    gyroZ=-0.01
calls=30    yaw=84.98    pitch=-2.73    roll=0.02    com=84.85    com180=-95.15    gyroZ=-0.01
pfodApp test
  1. Robot dance
  2. Keep on track
  3. Driving lanes
