Arduino Crash Kurs
Version vom 1. April 2016, 10:00 Uhr von Alexanderg (Diskussion | Beiträge) (→‎1. Dein erstes Programm)
 void setup()
   pinMode(13, OUTPUT);  // Pin 13 soll als Ausgang konfiguriert werden
 void loop()
   delay(1000);               // Warte 1000 Millisekunden (= 1 Sekunde)
   digitalWrite(13, LOW);     // Pin 13 soll auf LOW ( 0 Volt/Masse ) gesetzt werden
2. Dein erstes Programm mit Variablen
 void setup() {
 void loop() {
Expressions
Everything that can be calculated is an expression. Expressions are used to compute things. We will use expressions later for variables or functions calls.
Examples for expressions:
 13               => can be computed to 13 (it's simple right?)
 2 * 13           => can be computed to 26
 42 - 9 * 100     => can be computed as everything is known to compute it
 a + b - c + 20   => can be computed if a, b and c are known
Variables
A memory variable can contain a value (integer number, floating number, text character etc.). It is useful to use variables instead of repeating hard wired numbers. Here the same example, this time using a variable for the LED pin:
 // declare an integer variable named 'pinLED' and assign it the value 13
 int pinLED = 13;       // this is a comment
 void setup() {
   pinMode(pinLED, OUTPUT);   // here, we use the variable named 'pinLED' instead of the hard-wired number
 void loop() {
   digitalWrite(pinLED, HIGH);    // here, we use again the variable 'pinLED'
   delay(1000);
   digitalWrite(pinLED, LOW);     // here, we use again the variable 'pinLED'
   delay(1000);
Try it out! Variables can be integer number, floating numbers, logical (TRUE/FALSE), and text characters:
 int someIntegerNumber = 42;
 boolean someLogical = TRUE;
 float someFloatingNumber = 3.1419;
 char someCharacters[] = "Hello World";
A variable's contents can be re-assigned at any time in the program:
 int pinLED = 13;   // declare variable named pinLED and initialize it with value 13
 pinLED = 12;       // assign pinLED a new value (12)
You can even use calculations/expressions:
 int A = 4;
 int B = A * 42 + 15;
You may wonder what the values 'HIGH' and 'LOW' in the above code example are. These are integer constants that the Arduino library already did define for you (HIGH = 1, LOW = 0). Using variables and constants makes code more human-readable.
Functions
 pinMode
 digitalWrite
 delay
 void writeAndWait(int value){
   digitalWrite(pinLED, value);    // here, we use the parameter 'value' instead of a fixed HIGH/LOW value
   delay(1000);
 void loop() {
   writeAndWait(HIGH);  // call function with 'HIGH' (for parameter 'value')
   writeAndWait(LOW);   // call function with 'LOW' (for parameter 'value')
   return a + b;
 int c = addSomething( 4, 5 );
 void setup(){
   Serial.begin(19200);  // set the baud rate to use
 void loop(){
   delay(1000);
For-loops and blocks
Hello 0
Hello 1
Hello 2
Hello 3
... then the main loop restarts...
 void loop(){
     Serial.print("Hello ");
     Serial.println(counter);
   delay(1000);
Try it out!
Digital input
 int pinLED = 13;  // we use the Arduino onboard LED
 void setup(){
   pinMode(pinSwitch, INPUT_PULLUP);
 void loop(){
   Serial.println( value );
   delay(1000);
Try it out!
If-clauses
 void loop(){
   if (value == HIGH){
   else  {
   delay(1000);
if (numberX > 5)... // variable 'numberX' must be larger than 5
if (numberX > numberY) ... // variable 'numberX' must be larger than variable 'numberY'
if (numberX == numberY) ... // 'numberX ' must be equal 'numberY'
if (numberX < numberY) ... // 'numberX' must be smaller than 'numberY'
if ( (number > 5) && (number < 10) )... // logical AND: both conditions must be TRUE
if ( (number < 5) || (number > 10) )... // logical OR: only one condition must be TRUE
What you have learned
  • Variables can contain numbers (integer, float) or text (characters) and are placeholders for them.
  • Functions can containe blocks of code and are placeholders for the blocks.
