Arduino Crash Kurs
Version vom 1. April 2016, 11:12 Uhr von Alexanderg (Diskussion | Beiträge) (→‎2. Dein erstes Programm mit Variablen und serieller Konsole)
1. Dein erstes Programm
 void setup()
 void loop()
Aufgabe:
1. Baue folgende Zeile in die setup-Funktion ein:
  pinMode(13, OUTPUT);  // Pin 13 soll als Ausgang konfiguriert werden
2. Baue folgende Zeilen in die loop-Funktion ein:
  delay(1000);               // Warte 1000 Millisekunden (= 1 Sekunde)
  digitalWrite(13, LOW);     // Pin 13 soll auf LOW ( 0 Volt/Masse ) gesetzt werden
1. Lösung
 void setup()
 void loop()
Aufgabe:
4. Baue folgende Zeile in die setup-Funktion ein:
5. Baue folgende Zeilen in die loop-Funktion ein:
2. Lösung
 void setup()
 void loop()
Expressions
Everything that can be calculated is an expression. Expressions are used to compute things. We will use expressions later for variables or functions calls.
Examples for expressions:
 13               => can be computed to 13 (it's simple right?)
 2 * 13           => can be computed to 26
 42 - 9 * 100     => can be computed as everything is known to compute it
 a + b - c + 20   => can be computed if a, b and c are known
Variables
A memory variable can contain a value (integer number, floating number, text character etc.). It is useful to use variables instead of repeating hard wired numbers. Here the same example, this time using a variable for the LED pin:
 // declare an integer variable named 'pinLED' and assign it the value 13
 int pinLED = 13;       // this is a comment
 void setup() {
   pinMode(pinLED, OUTPUT);   // here, we use the variable named 'pinLED' instead of the hard-wired number
 void loop() {
   digitalWrite(pinLED, HIGH);    // here, we use again the variable 'pinLED'
   delay(1000);
   digitalWrite(pinLED, LOW);     // here, we use again the variable 'pinLED'
   delay(1000);
Try it out! Variables can be integer number, floating numbers, logical (TRUE/FALSE), and text characters:
 int someIntegerNumber = 42;
 boolean someLogical = TRUE;
 float someFloatingNumber = 3.1419;
 char someCharacters[] = "Hello World";
A variable's contents can be re-assigned at any time in the program:
 int pinLED = 13;   // declare variable named pinLED and initialize it with value 13
 pinLED = 12;       // assign pinLED a new value (12)
You can even use calculations/expressions:
 int A = 4;
 int B = A * 42 + 15;
You may wonder what the values 'HIGH' and 'LOW' in the above code example are. These are integer constants that the Arduino library already did define for you (HIGH = 1, LOW = 0). Using variables and constants makes code more human-readable.
Functions
 pinMode
 digitalWrite
 delay
 void writeAndWait(int value){
   digitalWrite(pinLED, value);    // here, we use the parameter 'value' instead of a fixed HIGH/LOW value
   delay(1000);
 void loop() {
   writeAndWait(HIGH);  // call function with 'HIGH' (for parameter 'value')
   writeAndWait(LOW);   // call function with 'LOW' (for parameter 'value')
   return a + b;
 int c = addSomething( 4, 5 );
 void setup(){
   Serial.begin(19200);  // set the baud rate to use
 void loop(){
   delay(1000);
For-loops and blocks
Hello 0
Hello 1
Hello 2
Hello 3
... then the main loop restarts...
 void loop(){
     Serial.print("Hello ");
     Serial.println(counter);
   delay(1000);
Try it out!
Digital input
 int pinLED = 13;  // we use the Arduino onboard LED
 void setup(){
   pinMode(pinSwitch, INPUT_PULLUP);
 void loop(){
   Serial.println( value );
   delay(1000);
Try it out!
If-clauses
 void loop(){
   if (value == HIGH){
   else  {
   delay(1000);
if (numberX > 5)... // variable 'numberX' must be larger than 5
if (numberX > numberY) ... // variable 'numberX' must be larger than variable 'numberY'
if (numberX == numberY) ... // 'numberX ' must be equal 'numberY'
if (numberX < numberY) ... // 'numberX' must be smaller than 'numberY'
if ( (number > 5) && (number < 10) )... // logical AND: both conditions must be TRUE
if ( (number < 5) || (number > 10) )... // logical OR: only one condition must be TRUE
What you have learned
  • Variables can contain numbers (integer, float) or text (characters) and are placeholders for them.
  • Functions can containe blocks of code and are placeholders for the blocks.
