Ardumower PCB
Version vom 13. September 2014, 10:42 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Starting the mower)
Needed parts
v0.9.3
If you know nothing about code, choose v0.9.3 and these parts:
  • Main functions
    • 1 x Arduino Mega 2560
    • 2 x L298N motor driver module
    • 3 x current sensor module ACS712-5
  • Perimeter sender (optional)
    • 1 x Arduino Nano
    • Coil 220µH, Elko 2,2µF/160V, Resistors (1 Ohm, 1K, 4,7K), Diode 1N4448
    • 1 x L298N motor driver module
    • 1 x Arduino Nano
    • 2 x Arduino Sound Sensor Module (must use LM386)
    • Capacitors (2 x 4,7nF, 2 x 100nF), Resistors (2 x 200k), 2 x Receiver coils 85mH
  • Additional modules
SVN version
If you want to be ready for the future, choose SVN and these parts: ...
Schematics
PCB assembly
...add a high resolution picture of the assembled PCB here...
It is recommended to use a voltage step-down converter (e.g. module using LM2596) to generate the 5V voltage for the Arduino and all additional modules. Before connecting, set the voltage of the converter to 5V. Warning : never connect more than 5V on the Arduino 5V pins, or you will damage the Arduino. Therefore, always measure the 5V voltage before connecting it to the Arduino 5V pin! All components together (as shown in the schematics) need about 5W power.
Flashing the Arduino
Arduino Version
It is verry Importent that you use the Arduino Version 1.5.6-r2 or above AND select the right Board.
First-time calibration
Wheel motors
ADC calibration
Diagnostic
Time of state machine's state (ms)
loop()-counts per second
choosen Verbose-Mode (0=counter readings/1=current values/2=current values)
current state machine state (FORW, REV, ROLL etc.)
drive home? (1/0)
"spd" - Control/speed motors: left (PWM), right (PWM), mower (RPM)
"sen" - Current limit exceeded counter motors: left, right, mower
"bum" - bumper counter: left, right
"son" - Ultrasonic-distance threshold exceeded (counter)
"pit/roll" - Tilt (computed by acceleration sensor)
"com" - compass course
"per" - Perimeter loop detected: counter
"bat" - Battery voltage
"chg" - Charging current
Starting the mower
Error counter / error beeps
I2C bus / error beeps
Config files
The main program wants to drive the left wheel motor by the value 100. The chosen robot config file is called by the main program with this command:
The chosen config file will then execute this command by calling the specific motor driver:
pfodApp
Important: Falls ein Software-Update aufgespielt wird, direkt nach dem Update via pfodApp einmalig alle alten Einstellungen löschen (Settings->Factory reset). Dadurch werden ggf. vorhandene Einstellungen gelöscht. Alte Einstellungen können zu Fehlverhalten führen wenn sich das interne Konfigurations-Format geändert hat.
