Motor driver
Version vom 30. Mai 2016, 16:15 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Motor driver (dual MC33926))
  • Two motors (with integrated gearing) for driving (wheel motors) with integrated encoders (for distance and speed control)
Voltages
As in all modern systems, the Ardumower uses 24V motors.
Wheel motors
  • steer the robot left/right
  • 24V (load current ~1A)
Features: up to 3A with integrated current sensor and thermal shut-down protection
Warning.pngProtector board is adviced to be used between controller and motor
Building video
Motor wiring (left motor):
black  ==== MC33926 M1OUT1
red    ==== MC33926 M1OUT2
brown  ---- PCB VCC
green  ---- PCB GND
blue   ---- PCB OdometryLeft (3)
purple ---- PCB OdometryLeft (4)
For right motor, use MC33926 M2OUT(1,2) and PCB OdometryRight accordingly.
odometry(3) --- 4.7k --- 5v
odometry(4) --- 4.7k --- 5v
Mower motor
Motor wiring (mower motor):
Motor controller (PID)
