Motor driver
Version vom 30. Mai 2016, 17:02 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Motor driver assembly (dual MC33926))
  • Two motors (with integrated gearing) for driving (wheel motors) with integrated encoders (for distance and speed control)
Voltages
Wheel motors wiring
  • steer the robot left/right
Wheel motor features:
  • 24V (load current ~1A)
Motor decrease noise
Protector PCB
Warning.pngProtector board is adviced to be used between controller and motor
Motor wiring (left motor):
Motor (black)  ==== MC33926 M1OUT1
Motor (red)    ==== MC33926 M1OUT2
Odometry wiring
Motor (brown)  ---- PCB VCC
Motor (green)  ---- PCB GND
Mower motor wiring
Motor wiring (mower motor):
Motor controller (PID)
