IMU
noise dps/sqrt(Hz) L3G4200D 0.03 BMG160/BNO055 0.014 MPU9250 0.01 L3GD20H 0.011 LSM9DS0 0.00875 BMI160 0.007 MAX21003 0.007 L2G2IS/L2G3IS 0.006 MPU9150/MPU6050 0.005 ADXRS290 0.004 GYPRO2300 0.00277
- Compass sensor: HMC5883L
- Gyro: L3G4200D
Calibration abstract
Example measurements
Calibration steps
This calibration can only be performed inside of the robot (in its final position). Start the compass calibration:
Calibration quality test
