Motor driver
Wheel motors (H-Bridge)
Arduino Digital Pin —> MOTOR-DIR Pin Arduino PWM Pin —> MOTOR-PWM Pin Arduino Analog Pin <— MOTOR-Current Sensor Pin
Popular modules
MC33926
M1_FB --- Motor1 current sensor output (Arduino) M1_PWM_D1 --- connect with jumper to GND M1_PWM_D2 --- connect with jumper to VDD M1_IN1 --- Motor1 PWM (Arduino) M1_IN2 --- Motor1 Dir (Arduino) EN --- connect with jumper to VDD M2_FB --- Motor2 current sensor output (Arduino) M2_PWM_D1 --- connect with jumper to GND M2_PWM_D2 --- connect with jumper to VDD M2_IN1 --- Motor2 PWM (Arduino) M2_IN2 --- Motor2 Dir (Arduino) EN --- connect with jumper to VDD VDD --- Arduino 5V
L298N
Connect in parallel:
L6203/STL6201PS
Features: up to 4A
L9958
Features: Arduino 240W H-bridge Motor Driver Board - SX8847, up to 8A (for Rotenbach SPM08-320 etc.)
Mower motor (MOSFET)
Choosing a driver
- price
Short-circuit current
Warning
- always remove blades
Example measurement:
- Rotenbach SPM08-320
- Wheel motor: 8A
- Mowing motor:
- Ambrogio L50
- Wheel motor: 4,5A
- Mowing motor: 22A
- Tianchen TC-G158
- Wheel motor: 5,4A
Current sensor
Approach "Hall sensor module"
