Version vom 7. Januar 2017, 20:06 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Actor and sensor control)
Message format
Not defined yet (ideas: NMEA 0183, SAE J1939, ...)
Messages
System control
  • Get implemented message types:
    • application control
    • actor and sensor control
    • propriertary
Application control
  • $RMMOW: Set mowing state (start mowing, stop mowing, go to docking station)
  • $RMSTA: Robot state event (robot state, errors, battery)
  • $RMSEN: Robot sensor event (sensor values, sensor trigger counters)
  • $RMCFG: Robot mower configuration (available sensors)
$RMMOW,s<cr><lf>
$RMSTA,s,e,b,h,d<cr><lf>
  • s: stopped (0), mowing (1), busy (2)
  • e: error
  • b: battery percent
  • d: moved distance in meter since last event
  • bl: bumperLeft
  • br: bumperRight
  • bc: bumperCenter
  • pfl: perimeterFrontLeft
  • pfr: perimeterFrontRight
  • pfc: perimeterFrontCenter
  • prl: perimeterRearLeft
  • prr: perimeterRearRight
  • prc: perimeterRearCenter
  • ih: IMUcompassHeading
  • ip: IMUpitch
  • pr: IMUroll
  • ga: GPSlatitude
  • go: GPSlongitude
Robot mower configuration (type of sensors)
  • o: Odometry available (1/0)
  • g: GPS available (1/0)
Rotate and move until sensor trigger
$RMMOV,d,r<cr><lf>
  • d: rotate degrees
  • r: move rpm
Keep ongoing action
$RMCOA<cr><lf>
Proprietary
