Version vom 7. Januar 2017, 22:20 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Robot state event (robot state, errors, battery))
Message format
NMEA 0183 compatible format
$IDMSG,data,<cr><lf>
message components:
  • $: start of message symbol
  • ID: RM (robot mower), DW (DW1000 beacons), ...
  • data: message data (see below)
example: $RMSEN,1,1,0,0,0,0,1,0,0,179,0,0,0,0<cr><lf>
Messages
  • $RMMOW: Set mowing state (start mowing, stop mowing, go to docking station)
  • $RMSEN: Robot sensor data event (sensor values)
  • $RMCFG: Robot mower configuration (available sensors)
  • $RMMOV: Rotate with x degrees per second and move with speed y RPM until sensor trigger
  • $RMKOA: Keep ongoing action (mower communications saftety)
  • $DWDAT: DW1000 beacons ranging
$RMMOW,s<cr><lf>
$RMSTA,s,e,b,c,h,d<cr><lf>
  • s: robot state: stopped (0), mowing (1), busy (2)
  • e: error
  • b: battery percent
  • c: charging percent
  • d: moved distance in meter since last event
  • bl: bumperLeft
  • br: bumperRight
  • bc: bumperCenter
  • pfl: perimeterFrontLeft
  • pfr: perimeterFrontRight
  • pfc: perimeterFrontCenter
  • prl: perimeterRearLeft
  • prr: perimeterRearRight
  • prc: perimeterRearCenter
  • ih: IMUcompassHeading
  • ip: IMUpitch
  • pr: IMUroll
  • ga: GPSlatitude
  • go: GPSlongitude
$RMTRG,bl,br,bc,pfl,pfr,pfc,prl,prr,prc,ip,ir<cr><lf>
  • bl: bumperLeft
  • br: bumperRight
  • bc: bumperCenter
  • ip: IMUpitch
  • pr: IMUroll
Robot mower configuration (type of sensors)
  • o: Odometry available (1/0)
  • g: GPS available (1/0)
Rotate and move until sensor trigger
$RMMOV,d,r<cr><lf>
  • d: rotate dps
  • r: move rpm
$RMKOA<cr><lf>
  • t: timestamp
Proprietary
