Version vom 8. Januar 2017, 00:09 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Robot state event (robot state, errors, battery, charger))
Message format
message structure: $IDMSG,data,<cr><lf>
message components:
  • $: start of message symbol
  • ID: RM (robot mower), DW (DW1000 beacons), ...
  • data: message data (see below)
example: $RMSEN,1,1,0,0,0,0,1,0,0,179,0,0,0,0<cr><lf>
Messages
  • $RMMOW: Set mowing state (start mowing, stop mowing, go to docking station)
  • $RMSEN: Robot sensor data event (sensor values)
  • $RMCFG: Robot mower configuration (available sensors)
  • $RMMOV: Move robot until sensor trigger
  • $RMKOA: Keep ongoing action (mower communications saftety)
  • $DWDAT: beacons ranging data (e.g. DW1000)
$RMMOW,s<cr><lf>
$RMSTA,ts,s,e,b,c,h,l,r<cr><lf>
  • ts: timestamp ms
  • s: robot state: stopped (0), mowing (1), busy (2), error (3)
  • e: error code
  • b: battery percent
  • c: charging percent
  • l: left odometry counter
  • r: right odometry counter
$RMSEN,ts,bl,br,bc,pfl,pfr,pfc,prl,prr,prc,ih,ip,ir,ga,go<cr><lf>
  • ts: timestamp ms
  • bl: bumperLeft
  • br: bumperRight
  • bc: bumperCenter
  • pfl: perimeterFrontLeft
  • pfr: perimeterFrontRight
  • pfc: perimeterFrontCenter
  • prl: perimeterRearLeft
  • prr: perimeterRearRight
  • prc: perimeterRearCenter
  • ih: IMUcompassHeading
  • ip: IMUpitch
  • pr: IMUroll
  • ga: GPSlatitude
  • go: GPSlongitude
$RMTRG,ts,ml,mr,bl,br,bc,pfl,pfr,pfc,prl,prr,prc,t<cr><lf>
  • ts: timestamp ms
  • ml: motorLeftStall
  • mr: motorRightStall
  • bl: bumperLeft
  • br: bumperRight
  • bc: bumperCenter
  • t: robot orientation tilt
Robot mower configuration (type of sensors)
  • o: Odometry available (1/0)
  • g: GPS available (1/0)
$RMMOV,l,r,p,i,d,o<cr><lf>
  • l: left motor target ticks per frame
  • r: right motor target ticks per frame
  • p: PID_Kp
  • i: PID_Ki
  • d: PID_Kd
  • o: PID_Ko
$RMKOA<cr><lf>
Beacons ranging data (e.g. DW1000)
  • t: timestamp ms
Proprietary
