Ardumower Sunray
Version vom 29. April 2017, 14:50 Uhr von Alexanderg (Diskussion | Beiträge) (→‎User interface (for testing/development))
  • PCB 1.3 (incl. MC33926 motor drivers)
  • Arduino Due
  • IMU GY-88 (MPU6050, HMC5883L)
  • 2 perimeter coils (left, right), perimeter sender
  • motors using odometry
  • Bluetooth module
Compass calibration
  1. Install IMU module 35cm away from metal parts. Use 1m cable so you can move the module out of robot for calibration. Do no use metal parts (screws etc.) within 5cm of the module, use plastic screws. Fixate everything within 5cm of the module. A small movement of a cable etc. will make the calibration useless. Verteileraufputzdose 2017-01-22.jpg
  2. Move IMU out of robot and power-on robot.
  5. Rotate IMU module slowly into all directions and collect > 20,000 measurements. Calibration ist performed transmitted continously to robot (robot confirms with a tone).
  1. On the PC, start 'processing_sunray'. The robot's sensors should be shown. At start (and every 3 minutes), the robot calibrates the Gyro and calibration status is shown in the user interface. After this is completed, you can verify the compass calibration by rotating the robot using the green joystick shown on the screen. Compass yaw and gyro yaw should be same up to 3 degree.
