Ardumower Sunray
Version vom 29. April 2017, 15:07 Uhr von Alexanderg (Diskussion | Beiträge) (→Lane-by-lane mowing)
- PCB 1.3 (incl. MC33926 motor drivers)
- Arduino Due
- IMU GY-88 (MPU6050, HMC5883L)
- 2 perimeter coils (left, right), perimeter sender
- motors using odometry
- Bluetooth module
Code
Compass calibration
- Move IMU out of robot and power-on robot.
- Rotate IMU module slowly into all directions and collect > 20,000 measurements. Calibration ist performed transmitted continously to robot (robot confirms with a tone).
- On the PC, start 'processing_sunray'. The robot's sensors should be shown. At start (and every 3 minutes), the robot calibrates the Gyro and calibration status is shown in the user interface. After this is completed, you can verify the compass calibration by rotating the robot using the green joystick shown on the screen. Compass yaw and gyro yaw should be same up to 3 degree.
Mapping
- Press 'mapping is OFF'. The map will be generated.
Localization
Random mowing
Lane-by-lane mowing
Perimeter tracking
- On the PC, choose 'track'
