Ardumower Sunray
- Arduino Due
- Bluetooth module
PCB1.2
Arduino Due operates at 3.3v - PCB1.2 is not designed to work for 3.3v, however you can modify and use it (with limitations):
- HC-05 module operates at 5v
Code
Compass calibration
- Move IMU out of robot and power-on robot.
- Rotate IMU module slowly into all directions and collect > 20,000 measurements. Calibration ist performed transmitted continously to robot (robot confirms with a tone).
- On the PC, start 'processing_sunray'. The robot's sensors should be shown. At start (and every 3 minutes), the robot calibrates the Gyro and calibration status is shown in the user interface. After this is completed, you can verify the compass calibration by rotating the robot using the green joystick shown on the screen. Compass yaw and gyro yaw should be the same up to 3 degree.
Bluetooth connection
String comPort = "COM9";
Recording / Playback
Mapping
Localization
A particle filter will estimate the robot's position on the map. You can reset the particle filter at any time by clicking 'reset particles'. In tracking mode, slightly different particle filter parameters will be used than during ordinary mowing. You can set the robot's position manually (kidnap robot) by clicking on the map.
Random mowing
Lane-by-lane mowing
Perimeter tracking
- On the PC, choose 'track'
