Ardumower Sunray
Ardumower Sunray is an alternative Firmware (experimental) for the Ardumower. It uses odometry, an IMU (gyro+compass) and a perimeter to localize itself on the perimeter and within the perimeter. A particle filter estimates the robot position on a map based on moved distance and absolute angle.
Currently, a PC must be connected to the robot to run the particle filter-based localization.
  • Ardumower PCB 1.3 (incl. MC33926 motor drivers) - for PCB1.2 see further below
  • Arduino Due
  • IMU GY-88 (MPU6050, HMC5883L) installed on a 'tower'
  • 2 perimeter coils (left, right), Ardumower perimeter sender
  • Bluetooth module and a PC using an USB Bluetooth dongle (e.g. Delock EDR 150m)
PCB1.2
  1. Remove Jumper JP3 (PowerA3.3) and Jumper JP12 (PowerA5.0) so no Arduino voltage regulators are used. Remove any measurement jumpers as well (Mess3.3 etc.).
  2. Set DC-DC U7 to 3.3v (all old 5v lines and VCC-lines on the PCB will now operate at 3.3v !)
  3. Set DC-DC U6 to 5.0v (all old 3.3v lines on the PCB will now operate at 5.0v ! It's recommended to make big labels on the PCB so you get not confused later!).
  4. MC33926 motor driver and INA169 module and odometry will now operate at 3.3v. Change VCC pin for the following modules to operate them at 5v:
    1. HC-05 module operates at 5v
    2. GY88 module (IMU) operates at 5v (SCL, SDA lines operate at 3.3v).
    3. LM386 modules (perimeter) operate at 5v.
Code
  1. Using Arduino IDE, flash the Sunray firmware onto your Arduino Due: https://github.com/Ardumower/Sunray
  2. Using 'processing_sunray', verify that the bluetooth connection to the Firmware is working.
Bluetooth connection
 String serialport = "COM14";
Compass calibration
  1. Install IMU module 35cm away from metal parts. Use 1m cable so you can move the module out of robot for calibration. Do no use metal parts (screws etc.) within 5cm of the module - use plastic screws. Fixate everything within 5cm of the module. A small movement of a cable etc. will make the calibration useless. Verteileraufputzdose 2017-01-22.jpg
  2. Move IMU out of robot (so you can freely rotate the module without the robot) and power-on robot.
  5. Rotate IMU module slowly into all directions and collect > 20,000 measurements. Calibration ist performed and transmitted continously to robot (robot confirms with a tone).
  1. In 'processing_sunray.pde', setup Bluetooth port.
  2. On the PC, start 'processing_sunray'. The robot's sensors should be shown. At start (and every 3 minutes), the robot calibrates the Gyro and calibration status is shown in the user interface. After this is completed, you can verify the compass calibration by rotating the robot using the green joystick shown on the screen. Compass yaw and gyro yaw should be the same up to 3 degree.
Recording / Playback
Mapping
Localization
A particle filter will estimate the robot's position on the map. You can reset the particle filter at any time by clicking 'reset particles'. In perimeter tracking mode, slightly different particle filter parameters will be used than during ordinary mowing. You can set the robot's position manually (kidnap robot) by clicking on the map in the user interface.
Random mowing
Lane-by-lane mowing
Perimeter tracking
  1. On the PC, choose 'track'
Particle filter tuning
 public static final float steeringNoise = 0.5;
 public static final float distanceNoise = 0.05;
