Ardumower Sunray
- Arduino Due
PCB1.2
- HC-05 module operates at 5v
Code
- Using Arduino IDE, flash the Sunray firmware onto your Arduino Due: https://github.com/Ardumower/Sunray
- Using 'processing_sunray', verify that the bluetooth connection to the Firmware is working.
Bluetooth connection
String serialport = "COM14";
Compass calibration
- On the PC, start 'processing_sunray'. The robot's sensors should be shown. At start (and every 3 minutes), the robot calibrates the Gyro and IMU calibration status is shown in the user interface. After this is completed, you can verify the compass calibration by rotating the robot using the green joystick shown on the screen. Compass yaw and gyro yaw should be always the same (up to 3 degrees).
Test functions
Verify the the robot is working correctly using these test functions:
- line : robot should move on a straight line
- line rev : robot should move reverse on a straight line
- rotate +90deg : robot should rotate counter-clockwise 90 degree
Recording / Playback
Mapping
Localization
Random mowing
Lane-by-lane mowing
In lane-by-lane mode, the robot will move one lane until a sensor triggers, then enter the next lane and continue.
Perimeter tracking
- On the PC, choose 'track'
Particle filter tuning
