Bluetooth
Version vom 19. Juni 2017, 16:19 Uhr von Alexanderg (Diskussion | Beiträge) (→‎PC remote control application)
  • via phone/tablet (Android App)
  • via USB Bluetooth dongle (PC serial console)
The phone menu includes:
  • Status information (battery voltage, charging current etc.)
  • Settings (Timer etc.)
  • Calibration (Motor, IMU etc.)
  • Remote control (Start/Stop, Switching on/off mower motor, blade modulation etc.)
Bluetooth module
Bluetooth HC-05
Bluetooth HC05 TX  --- PCB RX
Bluetooth HC05 RX  --- PCB TX
Bluetooth module configuration steps
  1. Configuration mode: The Bluetooth module must be in configuration mode for the next step:
    1. for HC05: Connect KEY pin to 3.3V after powering on the module
    2. for HC06/linvor: Do NOT pair/connect (LED must be blinking)
    3. for FBT06/MBTV4: First you have to solder the PIO11 pin to VCC (PIN 12) which is 3.3 Volts using a thin wire.
  2. Baud rate: Blueooth module and Arduino Mega must use the same baud rate (19200) - The baud rate of the BT module can be changed via Ardumower serial console. Connect Ardumower Mega board to your PC (USB), enter the serial console in the Arduino IDE (CTRL+M), and choose baud rate 19200, then choose 'd' to enter the Ardumower menu, '3' for communications menu, and '3' to configure the module to the correct baud rate.
  3. Restart: After your BT module is configured successfully, remove KEY pin connection again (HC05), and restart module.
  4. Pairing: The BT module must be 'paired' with your Android device once (via Android device settings). On the Android device, choose symbol "Settings" (via Android menu). Now choose "Wirless and Networks->Bluetooth Settings" and "Find device". Finally, choose "pair with this device" and enter your pin (very often "1234"). The Bluetooth module should now appear as "paired".
  5. pfodApp: Now you can start pfodApp/ArduRemote to connect to the Ardumower.
We have developed a remote control application for PC (developed in Processing/Java):
  1. Download Windows 32 bit executable (can be run on 64 bit too) and extract it:
  1. Download and install Java runtime: https://java.com/de/download/
Communication protocol
Example communication:
   title
   [text1]
   [text2]
   [text3]
Sensor logging
  1. menu demo v0.8.8
  2. menu demo live v0.8.8
  3. tutorial video
