Chassis (English)
Version vom 28. Mai 2018, 11:01 Uhr von Alexanderg (Diskussion | Beiträge) (→Ardumower 1.0 Chassis specifications)
- Wheels: 250mm diameter
- Free wheel: 125mm diameter
- Battery: Lithium-Ion 29.4V
- Max. incline: approx. 30%
- Overall impression
- Loundness test
- Gear motor test
- Gear motor hardness test
- Mowing motor hardness test
- Robot releases itself
- Plastic blades test
- Rain sensor test
- 3D simulation
Assembly: required tools
- Screw driver
- Imbus screw driver
