Ardumower Gasoline
This Do-It-Yourself (DIY) project describes how you can convert your ordinary gasoline mower into a remote controlled (R/C) mower using Ardumower parts.
Video
Features
- 2x gear motors running at 31 rpm, 2.45 Nm
- powered by 29.4v Lithium-Ion battery
- wireless control via 2.4 Ghz model R/C control
Parts list
All parts can be purchased in the shop. Click here to add all parts below to your shopping cart:
Click on a part for more details:
- 2x 260mm tires
- this 3d printed tire adapter or this one
- 1x free wheel
- 2x clamping elements
- 2x Ardumower gear motors
- 2x motor drivers BTS7960
- 1x Ardumower Power pack charger
- 1x Ardumower Power pack battery
- 1x DC/DC converter
- 1x Arduino Nano
- Arduino Nano I/O shield
- a model R/C receiver and a remote control (e.g. 2.4 Ghz R/C control)
- 1x fuse holder
- 1x fuse 4A
- 1x diode 10A
- 1x emergency switch
- 1x charging socket
- Arduino wires female-to-female
- 2 meter wire, 0.5 mm^2 section for wiring motor drivers
- 5x M8 screws, nuts, slices for mounting free wheel
- 8x M4x90 screws, slices for mounting tire on clamp
- 8x M4 screws, slices for mounting gear motors
Motors
Free wheel
Control box
Wiring
left BTS7960 Arduino pin GND GND VCC +5V R_EN A1 L_EN A0 R_PWM 9 L_PWM 10
right BTS7960 Arduino pin GND GND VCC +5V R_EN A3 L_EN A2 R_PWM 3 L_PWM 11
Wiring Arduino and model R/C receiver
model R/C receiver Arduino pin GND GND VCC +5V CH_Steering 5 CH_Speed 6
Arduino code upload
- Download and install Arduino IDE
- Upload this code to your Arduino Nano: https://github.com/Ardumower/ardumower/blob/master/code/tests/rcmower/rcmower.ino
Note: After uploading, you can run the Arduino IDE serial console (CTRL+SHIFT+M) at 115200 baud to monitor the R/C signal coming in:
steer=0 speed=100 mleft=255 mright=255 steer=0 speed=100 mleft=255 mright=255 steer=0 speed=100 mleft=255 mright=255 steer=0 speed=100 mleft=255 mright=255 ...
