Raindancer Firmware (English)
I am currently translating this side.!!! Attention! The software is still changing and can be changed / extended at any time.
- 1 Download
- 2 Overview
- 5 config.h
- 6 QUICK START TO MOW
- 6.6 Mähmotor Inbetriebnahme
- 6.8 Konfiguration Bluetooth
- 6.10 Erste Testfahrt
- 7 TUNE UP
- 7.2 Charge Service
- 7.3 Watchdog
- 7.5 I2C Bus
- 7.6 RTC
- 7.7 EEPROM
- 7.10 Spiralfahrt
- 7.11 Perimeter Tracking
- 7.12 Schnelle Rückkehr
- 8 Perimeter Sender
- 9 Troubleshooting
The Raindancer firmware is located in the directory code \ Raindancer The transmitter firmware is located in the directory code \ sender
Overview
- Regensensor einbinden
- SRF08 einbinden
- PCB1.3 mit Arduino DUE
- Original Ardumower Mähmotor
- BT Modul
- 24V Spanungsversorgung
- RTC mit EEPROM
- Durchfahrende Ladestation
clc.v,s Motor stoppen
z //mow motor start
t //mow motor stop
Spiralfahrt
bb.flagCruiseSpiral = true;
Schnelle Rückkehr
Abfrage der States
... } return BH_RUNNING; }
- 1. 12V vorhanden
- 2. 5V vorhanden
