Ardumower Sunray
400px
Demo video: coming soon
  • Optimized for Arduino Due
  • Ardumower PCB 1.3 (incl. MC33926 motor drivers)
  • Arduino Due
  • SimpleRTK2B - starter kit LR IP67
  • Bluetooth BLE module (CC2540) and a smartphone (Android/iOS)
IMPORTANT: Verify the pinout of your BLE module is matching your PCB pinout (shown at the PCB1.3 back side)!
4. Set JP12 (GPS voltage) to 5V
5. Set JP7 (GPS signal level) to 5V
PCB1.3 GPS
  1. Make sure you have the simpleRTK2B marked as 'BASE' in your hands (look at simpleRTK2B PCB label at backside!)
  2. Connect Xbee LongRange antenna
  3. Connect GPS multifrequency antenna
  4. Connect USB 5v to power the base module
  5. Your base antenna should have clear view to the sky in all directions without any obstacles. For best results install GPS antenna on the roof.
PCB 600px
  1. Make sure you have the simpleRTK2B marked as 'ROVER' in your hands (look at simpleRTK2B PCB label at backside!)
  2. Connect XBee LongRange antenna
Rover configuration
1. Connect SimpleRTK ROVER module via USB to your PC.
3. Choose 'Receiver->Connection' and choose your rover.
4. Choose 'View->Configuration View'. Choose configuration message 'MSG (Messages)' and select one message after the other in the list (0A-37 MON-HW3, 0A-09 MON-HW, ..., etc.). For each message, make sure the selected message is NOT activated for UART1. Example for message '01-22 NAV-CLOCK' that has been deactivated for UART1:
5. Finally only activate message '01-3C NAV-RELPOSNED' for UART1.
Firmware
3. Start Arduino IDE, and upload the sketch to your PCB1.3.
1.1. Download Viewer App:
1. Once your base module is sending satellite reference data to your rover module (via the XBee LongRange modules), the LED 'XBEE->GPS' on the rover will blink. Verify that by turning OFF and ON the base module!
2. When the rover has NOT yet found its position the GPS solution ('sol') in the App shows 'invalid'. When the rover has found its position, the GPS solution ('sol') will change to 'float' (unprecise) or 'fixed' (precise) and the rover LED 'GPS FIX' will be ON.
Discussion / forum thread
  1. coming soon
