Ardumower Sunray
Version vom 24. Januar 2020, 17:05 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Rover configuration)
600px
Demo video: coming soon
  • Optimized for Arduino Due
  • Ardumower PCB 1.3 (incl. MC33926 motor drivers)
  • Arduino Due
  • SimpleRTK2B - starter kit LR IP67
  • Bluetooth BLE UART module (CC2540) and a smartphone (Android/iOS)
  2. Connect Xbee LongRange antenna
  5. Install the GPS base antenna - it should have clear view to the sky in all directions without any obstacles. For best results install GPS antenna on the roof.
PCB 600px
  2. Connect XBee LongRange antenna
  3. Connect GPS multifrequency antenna
Rover configuration
1. Connect SimpleRTK ROVER module USB port marked as 'POWER+GPS' to your PC. Do NOT turn on the Ardumower!
4. In this step we want to turn off all broadcast messages except one. Choose 'View->Configuration View'. Choose configuration message 'MSG (Messages)' and select one message after the other in the list (0A-37 MON-HW3, 0A-09 MON-HW, ..., etc.). For each message, make sure the selected message is turned off for UART1. Do NOT change anything for the ports UART2, USB etc. - only turn off all messages for UART1. Example for message '01-22 NAV-CLOCK' that has been deactivated for UART1:
5. Finally, activate message '01-3C NAV-RELPOSNED' for UART1 (this is the only message we want to be broadcast).
Firmware (Arduino Code)
Discussion / forum thread
  1. coming soon
