Ardumower Sunray
Ardumower Sunray is an alternative Firmware (experimental) for the Ardumower. It uses RTK GPS to localize cm-precise without a perimeter wire. It requires PCB1.3, Arduino Due, ArduSimpleRTK kit and a phone (Android/iOS).
600px
Demo video: coming soon
  • Optimized for Arduino Due
  1. Install the GPS base antenna - it should have clear view to the sky in all directions without any obstacles. For best results install GPS antenna on the roof. Alternatively, if you have an open area (without trees and other obstacles), you can install the base antenna on a tripod.
400px PCB
9. Choose configuration message 'CFG (Configuration)' and click on 'Send' to make the configuration in the rover persistent.
10. IMPORTANT: Disconnect USB cable from rover module!
Firmware (Arduino Code)
Discussion / forum thread
