Ardumower Sunray
NOTE: everything here is still in development! Use Azurit Firmware instead if you need a working firmware...
600px
Demo video: coming soon
  • Optimized for Arduino Due
400px PCB
Firmware (Arduino Code)
Both, the robot's odometry and RTK are used to localized the robot. Therefore, it is important to verify that the odometry is working correctly as shown below:
Discussion / forum thread
