Ardumower Sunray
NOTE: everything here is still in development! Use Azurit Firmware instead if you need a firmware with more features...
600px
Demo video: coming soon
  • Optimized for Arduino Due
400px PCB
Firmware (Arduino Code)
Both, the robot's odometry and GPS-RTK are used to localized the robot. Therefore, it is important to verify that the odometry is working correctly as shown below:
GPS (invalid, float, fix)
Discussion / forum thread
