Ardumower Sunray
NOTE: everything here is still in development! Use Azurit Firmware instead if you need a firmware with more features...
Demo video: coming soon
- Optimized for Arduino Due
These are the hardware requirements to add RTK-GPS in your Ardumower:
- SimpleRTK2B - starter kit LR IP67 (you can get them pre-configured here)
- Bluetooth BLE UART module (CC2540) and a smartphone (Android/iOS)
Firmware (Arduino Code)
GPS (invalid, float, fix)
Discussion / forum thread
