Ardumower Sunray
NOTE: everything here is already working but in early prototype phase! Use Azurit Firmware instead if you need a firmware with more features...
Demo video: coming soon
- Optimized for Arduino Due
RTK-GPS uses two GPS receivers, one for the reference antenna (base) and one for the robot mower (rover) which both communicate in realtime via radio modules. The base constantly sends correction data so the rover can compute its cm-precise position. In the RTK-GPS kit, everything required (receivers, radios, antennas etc.) is included.
To be able to use RTK-GPS, your robot mower should have a good view to the sky at all locations. RTK-GPS will not work directly near walls, under large trees, in buildings etc.
- SimpleRTK2B - starter kit LR IP67 (it's recommended to purchase the RTK-GPS modules via Marotronics as you get them pre-configured for the Ardumower there)
- Bluetooth BLE UART module (CC2540)
Firmware (Arduino Code)
GPS (invalid, float, fix)
Discussion / forum thread
