Ardumower Sunray
Warning.png WARNING: everything here is already working but in early prototype phase!
Use Azurit Firmware instead if you need a firmware with more features...
Demo video: coming soon
  • Optimized for Arduino Due
  • Incomplete (Sunray is 'work in progress') - features like 'exclusion areas' and 'obstacle avoidance' are going to be added soon.
  • Experimental (never run your Ardumower unattended with this firmware)
PCB     PCB
400px PCB
9. Install XBee antenna and GPS antenna on the Ardumower. The GPS antenna must be mounted at the position of the tire axle and between both tires (see below):
Firmware (Arduino Code)
GPS (invalid, float, fix)
Discussion / forum thread
