Ardumower Sunray
Ardumower Sunray is an alternative Firmware (experimental) for the Ardumower DIY robotic mower system. It uses RTK GPS to localize cm-precise without a perimeter wire. It requires Ardumower PCB1.3, Arduino Due, ArduSimple RTK kit, Bluetooth BLE and a phone (Android/iOS).
WARNING: everything here is already working but in early prototype phase!
- 1 Significant changes compared to Azurit Firmware
- 2 Requirements
- 3 Bluetooth BLE UART module
- 4 PCB1.3 GPS pin fix
- 5 PCB1.3 odometry divider
- 6 RTK base
- 7 RTK rover
- 8 Rover configuration (messages)
- 9 Firmware (Arduino Code)
- 10 Phone App
- 11 Odometry test
- 12 GPS (invalid, float, fix)
- 13 Discussion / forum thread
- Optimized for Arduino Due
- Incomplete (Sunray is 'work in progress') - features like 'exclusion areas' and 'obstacle avoidance' are going to be added soon.
- Experimental (never run your Ardumower unattended with this firmware)
- SimpleRTK2B - starter kit LR IP67 (it's recommended to purchase the RTK-GPS modules via Marotronics as you get them pre-configured for the Ardumower there)
