Ardumower Sunray
This page describes how to build an RTKG GPS mower. It requires an Ardumower DIY robotic mower system using Sunray Firmware and a RTK GPS kit.
Ardumower Sunray is an alternative Firmware (experimental) for the Ardumower DIY robotic mower system. It uses RTK GPS to localize cm-precise without a perimeter wire. It requires Ardumower PCB1.3, Arduino Due, ArduSimple RTK kit, Bluetooth BLE and a phone (Android/iOS).
Ardumower sunray.jpg Ardumower sunray app.jpg Video.png DEMO VIDEO
  • Optimized for Arduino Due
PCB     PCB
400px PCB
PCB     PCB
Firmware (Arduino Code)
Discussion / forum thread
600px
