'Mows like on rails...' This is an RTK GPS-based mower that you can build yourself! The best thing is: Ardumower RTK doesn't need a perimeter wire as it uses (cm-precise) RTK GPS.
DEMO VIDEO
- Optimized for Arduino Due
Incomplete (Sunray is 'work in progress') - features like docking, GPS signal-loss detection, obstacle detection and avoidance are going to be added soon.
400px
5. In this step we want to turn off all broadcast messages except one.
Choose 'View->Configuration View'. Choose configuration message 'MSG (Messages)' and select one message after the other in the list (0A-37 MON-HW3, 0A-09 MON-HW, ..., etc.). For each message, make sure the selected message is turned off for UART1. Do NOT change anything for the ports UART2, USB etc. - only turn off all messages for UART1.
Example for message '01-22 NAV-CLOCK' that has been deactivated for UART1:
Discussion / forum thread
- https://forum.ardumower.de/threads/sunray-firmware-goes-rtk.23690/
600px
