Ardumower Sunray
'Mows like on rails...' This is an RTK GPS-based mower that you can build yourself! The best thing is: Ardumower RTK doesn't need a perimeter wire as it uses (cm-precise) RTK GPS.
|<iframe width="560" height="315" src="https://www.youtube.com/embed/yDcmS5zdj90" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
PCB     PCB
  • Optimized for Arduino Due
400px PCB
PCB     PCB
Discussion / forum thread
600px
